microcontroller connection with main powers
Mnawer Hadid
Joined Mar 16, 2019
8
hi, im working on a project. which is unit for cell culturing process. I need to connect the microcontroller used to control the uv light and user interface with main powers.
how can I do this?/
thank you
MaxHeadRoom
Joined Jul 18, 2013
30,735
Isolated power supply, look at any small SMPS such as the Wall Wart plug-in to any socket outlet. Do you just need 5vdc?
Where are you located?
Max.
Mnawer Hadid
Joined Mar 16, 2019
8
Hi max,
as I mentioned earlier, we are designing a unit where 3d culturing can take place. so we need to control the temperature, humidity and uv light to cure the cell. we are using Arduino uno to control everything. but I need to know how can I connect all the system to the main power supply in the world.
thank you so much for your help
MaxHeadRoom
Joined Jul 18, 2013
30,735
I assume 'the World' means your local power service provider?
What are the operating of the systems apart from the micro and the power demands?
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,735
For any smaller DC load current versions you may require, an opto on the Micro to drive a 2n7000 or other logic gate Mosfet may work. Also the opto could drive a Triac.
Also the micro will drive a logic Mosfet directly if isolation is not required for a particular load.
Max.
cmartinez
Joined Jan 17, 2007
8,803
Max.
Yeah, a triac can be the cheapest option. And replacing them can be easier if they're mounted on the PCB using ordinary screw terminal blocks.
bertus
Joined Apr 5, 2008
22,964
No, they do not have the same function.
The SSR is a relays to control a device.
The SMPS is a to provide power to a device.
Bertus
MaxHeadRoom
Joined Jul 18, 2013
30,735
Are you citing the Opto22 modules?
They are nice, but limited in current rating, also if using them as a replaceable module you need to either use one of the Opto22 distribution boards or custom make the receptacle on a PCT board, which I have actually done in one case.
Also available with 5vdc input.
Max.
