Is there a mirror that moves on a single axis, from vendor or used in something canibalizable that you may know ?
Am after 45 degrees movement in about half a second, about 50 mm x 10mm mirror. Which is not micro at all.
It is to deflect a laser to sweep a target. Perhaps a voice coil mechanism ? Galvo ? What else is the industry using ? Motors, gears and servos may not last years of 24/365.
Does not need to be in an 'integrated circuit' package
