Memory Rank and Memory Bank
Electronic_Maniac
Joined Oct 26, 2017
253
I have gone through these two terms (Bank and Rank with regards to memory IC) and I still didn't get perfect clarity.
Can someone provide me a little write up explaining the above two terms with a neat example?
I would be really grateful. :)
Thanks.
Alec_t
Joined Sep 17, 2013
15,149
It is often convenient to select/address memory locations a group at a time. Suppose you have a memory module consisting of several DRAM (or static RAM, or ROM) ICs. Each IC can consist of several memory blocks, each block containing several memory locations. According to the JEDEC definition in that link, each IC (or set of ICs) can be considered as a 'rank', whereas each memory block (or set of blocks) within an IC can be considered as a 'bank'.
