Manufacturers provide that information:
after reading 10 articles about KVL i think i almost understand this. Just one thing what is not clear for me, why collector has negative mark? Teacher meantioned that base and collector has to be positive, and emmiter - negative.In saturation both junctions are forward biased.
Test your knowledge by wiring up some circuits so you can verify your understanding experimentally.I understand the KVL
Positive and negative relative to what? Post a schematic.Just one thing what is not clear for me, why collector has negative mark? Teacher meantioned that base and collector has to be positive, and emmiter - negative.
In a simple words, i wanted to ask if transistor works like a diode when its saturated ant current flows from B to E and from B to C?Positive and negative relative to what? Post a schematic.
Was your teacher not able to teach you KVL?
No, a diode has no current gain.In a simple words, i wanted to ask if transistor works like a diode when its saturated ant current flows from B to E and from B to C?
But why it has same marking as a diode?It might be clearer from this schematic:
\( \small V_{R1}+V_{DCB}=V_{LED}+V_{R3}\)
or
\( \small V_{R1}=V_{LED}+V_{R3}-V_{DCB} \)
Corrected equation.
The junctions in a transistor are PN junctions and share many characteristics with diodes, but diodes can't be substituted for transistors. In the schematic I used to illustrate KVL, the diodes were to help visualize voltage drop and the reason for it.But why it has same marking as a diode?
The transistor wasn't being driven hard enough to go into saturation. If you're trying to learn, be careful when reading or watching stuff from people who don't know what they're doing; that's a classic example of the blind leading the blind (no offense intended to persons with impaired vision). There's all kinds of misinformation on the internet. This forum is better if you get multiple people responding because Peer review might root out any mistakes.Its also strange that the voltage across CE is kinda high
Yeah i tottaly agree with that, but there is voltage measured acros BE , and when the LED is lightining, the voltage across BE is 0,7V , doesnt that mean that transistor should be saturated?The transistor wasn't being driven hard enough to go into saturation. If you're trying to learn, be careful when reading or watching stuff from people who don't know what they're doing; that's a classic example of the blind leading the blind (no offense intended to persons with impaired vision). There's all kinds of misinformation on the internet. This forum is better if you get multiple people responding because Peer review might root out any mistakes.
I learned this stuff 40 years ago and for most of my working career, I was working in different aspects of the field.
The voltmeters in that simulation show the C-B junction being reverse biased, so the transistor is in it's active region.Yeah i tottaly agree with that, but there is voltage measured acros BE , and when the LED is lightining, the voltage across BE is 0,7V , doesnt that mean that transistor should be saturated?but there is over 1V voltage across CE
The transistor is biased by the components it's connected to. Using a battery or power supply to bias the transistor junctions wouldn't be very useful.If i understand the reverse biased good, that means that the emmiter base and collector is connected to the reverse battery terminals, but how is that possible if in that circuit there are no additional batteries?
You're being sloppy with your terminology and need to do some study so you can better express your thoughts.And how can a LED light up when the transistor is reverse biased? I thought that the transistor must be forward biased to allow current flow through CE and light the LED
Why do you say that? Don't you see something in parallel with R4? What does KCL say?isnt the R2 and R4 in series with each other? So the current should be the same for both?
