Measuring diode drop in both directions with meter??
dl324
Joined Mar 30, 2015
18,289
Not for a regular diode.
If you had a low voltage zener, it might work. It depends on the voltage used by the meter. I think mine only works to 2 volts.
AlbertHall
Joined Jun 4, 2014
12,624
With the diode in circuit, yes, you might read conduction in both directions - one direction being the forward conduction of the diode and in the other direction conduction through some other component in the circuit. For instance in the circuit below, checking the diode, the base-emitter of the transistor will conduct in the reverse direction.
