Measuring Current using Current transformer
Qual
Joined Aug 5, 2016
48
Hi ,
i was trying measure current using Current Transformer but i see spikes at the output of transformer and cant see proper waveform on oscilloscope.
Attached is the waveform...
Any suggestion.
I want feed the voltage to Micro controller so that i can display same on LCD.
DickCappels
Joined Aug 21, 2008
10,661
That waveform is normal for some types of loads, especially capacitor input filters.
What is the source (AC power line?) and load (input to a power supply or electronic appliance?) for the circuit you are measuring?
DickCappels
Joined Aug 21, 2008
10,661
I am going to take a guess: You are not using a transformer that was designed to measure current or you do not have an adequate shunt. What kind of transformer are you using? What are you using for a shunt? (Shunt: The resistor across the primary that sets the scale)
Qual
Joined Aug 5, 2016
48
i am using 56100C current transformer from Murata for measuring current.
30,854
What kind of current are you measuring, would a ACS712 work for you, although they are in circuit type rather than transformer, comes with isolation build in.
The can be had for a couple of $'s on ebay with circuit, 5A, 20A and 30amp ranges.
Qual
Joined Aug 5, 2016
48
i want to measure the AC and DC current. Want to build my own circuit.... so this attempt
