Measurements on buffer and weird output waveform
luma
Joined Nov 5, 2015
52
Hi guys, here again, As you can remember from the other post I wanted to understand what's wrong in the circuit (CMOS buffer or push pull amplifier) attached.
Most of you gave me good suggestions to make it work. However before to give up with that buffer I wanted to check for real if that buffer I proposed cannot really work and how it behaves. I built the circuit by using the typical CD4007 and creating a buffer . In the attachment I wrote the number of pins and the signals.
My test consisted to bias the input of the buffer with a voltage around 5V and check what happen if I increase the input voltage of the signal. This test could give me some info about what is the caratteristc curve (vo/vin) of the buffer. However the output seems to be distorted by the buffer and I don't get why.
I attached some pictures about measurements with oscilloscope. the green line is the input, the yellow line is the output.
Anyone can explain me what happen when I increase the amplitude of the input signal? And why there is a distortion?
luma
Joined Nov 5, 2015
52
dl324
Joined Mar 30, 2015
18,339
What do you mean? How would you connect the bulk of the mosfet?
The bulk of a PMOS device is normally connected to the positive supply and the bulk of the NMOS device is normally connected to the negative supply. In the CD4007, those connections are already made and can't be changed.
luma
Joined Nov 5, 2015
52
Thanks for your comment, however as is shown in the schematic the bulk are connected as you said. Look better . Second : the bulks on the CD4007 available externally and not internally connected. Look better to the datasheet.
(p.s in my schematic I forgot to draw the number of the pin for the bulks but the bulk of NMOS is 7 top GND and the bulk of PMOS is 14 to VDD)
luma
Joined Nov 5, 2015
52
PIN 14 to VDD and pin 7 to GND. Also a push pull amplifier do not provide any voltage gain .
Thank you jony for your answer can you quote, the question, otherwise i cannot understand to which question or sentence you are answering.
luma
Joined Nov 5, 2015
52
You need to follow your own advice. In your schematic, you show the connections backwards. The bulk of the PMOS is connected to 0V and the bulk of the NMOS is connected to 10V.
AND if you see carefully also in my previous thread the bulk are connected correctly
bertus
Joined Apr 5, 2008
22,930
Which connections did you use?
In the datasheet there is this given for biasing:
I have also attached the PDF that contains the shown images.
luma
Joined Nov 5, 2015
52
thank you for your answer the pin i m using are drawed in my schematic, please check there, however is the second pair of mosfet in the image you post it.
The schematic you show and suggested by the company is just for na inverter while
i built a push pull amplifier
bertus
Joined Apr 5, 2008
22,930
Why do you post the pictures on its side?
I will NOT turn my monitor to view the image !
It can easily be corrected using any kind of paint program:
