12V, 12V, 24Vwhat is the V peak and peak to peak of a square signal between 0v to -12V
and for 0v to 12v
and for -12v to 12v
if i have a square signal between 0v to 5v12V, 12V, 24V
5V, 5V.if i have a square signal between 0v to 5v
how much its the Vpeak ? and Vpeak to peak ?
thank you sir for your help5V, 5V.
lol i have exam in microcontrollers and analog systemI think you are getting confused with the relation to the common point of reference, for example an AC waveform could be referred to Peak to Peak, either side of the zero point, or reference point, whereas peak voltage as in a DC, zero to plus or zero to minus. .
IOW a peak to peak, generally transitions either side of zero.
In my take on the meaning of the expression.
Max.
So, Do I take it helped?lol i have exam in microcontrollers and analog system
For a negative rectified sinewave, it would be -2V.Vpeak=-2v or 2v ?
You need to see where the zero point is set on the oscilloscope, with no signal, as determined by the vertical position control.Or in the oscilloscope there no sign plz help me i have exam tomorrow.
You teacher is the one that's woefully ignorant and confused, so don't let that confuse you.My teacher said oscilloscope cant measure negative voltage so im confused
