MCP6N11 LTspice model not working
Alec_t
Joined Sep 17, 2013
15,158
The fault may not lie with the amp model itself. It's a common error message. Try adding a few parasitic values to components in your schematic., e.g. give any voltage source or inductor some small but finite internal series resistance.
Alec_t
Joined Sep 17, 2013
15,158
Try right-clicking V1 and/or V2 and setting its series resistance parameter to 1 Ohm. Adding a decoupling cap of 1uF across V1 and/or V2 might also help.
Alec_t
Joined Sep 17, 2013
15,158
So it seems the problem could well be within the IC model.
Does putting some small resistance between Vref and Vss make any difference?
You could also try editing the simulation command by checking "Skip initial operating point solution".
Lightium
Joined Jun 6, 2012
320
Well, for starters R94 and R97 can't be zero. So I will change their values to 0.2 for now, again it's late for me. See you later.
Alec_t
Joined Sep 17, 2013
15,158
I've just noticed your model seems to be for the 'Minimum Gain = 5' version of the chip, but you have set the gain = 2 via R93,R96. Could that be an issue?
