Hello All,
I have built a voltage boost circuit using MC34063 to boost from 3.2V to 5V with 350mA output current.
The problem is I am getting 5V output when measured witha DMM but when I connect even a small load like a microcontroller, the output voltage drops to around 1.5 or 2 V.
I have used the standard schematic of voltage boost mentioned in the datasheet. The values are as follows:
R:180 ohms
Rsc: 0.2 ohms
Ct: 22pF
L: 22uH
Cin: 10uF
Cout: 10uF
R3/R4 for boosting: 3.3K and 10Kohms
The inductor is a small one which resembles a 1/2 watt resistor.
Please help
R:180 ohms
Rsc: 0.2 ohms
Ct: 22pF
L: 22uH
Cin: 10uF
Cout: 10uF
Please help
