MC-2100LT-12 motor controller
niartloac
Joined Mar 10, 2020
3
When I have A+ and A- disconnected from motor and push the start speed the LED light blinks constantly and shows 165 VDC output. When I turn off power and connect A+ and A- to the motor and hit the speed button the motor spins and then stops. The LED is now blinking 4 times and then a pause with 0 VDC. Any suggestions?
30,672
The only thing I have seen on the 4 blinks fault, is it mentions "The switch is bad, replace board" but could not answer the question as to which "Switch" I think it was a shot in the dark.
Utube video.
I suspect it is either Mosfet or mosfet driver.
Does the LED flash slowly when A+/A- disconnected?
Or is it rapid flash?.
niartloac
Joined Mar 10, 2020
3
Utube video.
flashes rapidly
