MAX4420 MOSFET Driver Overheating
cv43coeralsea
Joined Mar 17, 2021
22
I have a MAX4420 driving an IRF510 Mosfet in the circuit below. The second I turn on the power the 4420 gets super hot. This happens whether "JI" is closed or open. I have also tried with/without 5Ohm resistor, no difference.
I must be overlooking something basic. (I have checked for shorts and opens many times. Routing is correct. )
38,868
Does pin 1 have a dot next to it?
The wiring, as shown, is looking from the top of the IC.
If it's all correct then you may have a bad IC.
cv43coeralsea
Joined Mar 17, 2021
22
Yes, the wiring is looking top down. No dot per say but the little half moon at the top of the chip. I'll try another driver IC although I had put a new one in last night replacing the first one.
