The object sensor output is open collector transistor .
i used 470 uf with 12v , i got 7 min period
sorry guys, i forgot to till you while the object still crossing the sensor the lamp should be on
and this cant achieve with iimagine circuit and i dont know if i can do that using 555 timer
could you advice me to use microcontroller to do what i need?
Regards
Which planet are you on?I will order cmos 555 and 4060 counter ,, 30 days at least to deliver
Even better! no idle current wasted.sorry guys, i forgot to till you while the object still crossing the sensor the lamp should be on
thank you for your appreciated effort ,i test a code on arduino nano it works well.mBlock visual programming language and an Arduino Nano, Uno, even an 8
pin ATTINY85 would do, ~ 2% accurate timing.
Here is what i think are your basic requirements done in mBlock.
You drag / drop blocks, config, and the tool generates and uploads the Arduino "C" code.
The code it generates for you looks like this -
All you need is board, maybe an R in series with light sensor to make a voltage
divider to feed to the UP A/D pin and of course power.
If you use boards that have onboard xtal timing accuracy will be << 1%,
if ATTINY85 ~ 2%
Regards, Dana.
i test the circuit with 470u, i got about 9.5 Min. thank youEven better! no idle current wasted.
Since you mentioned your sensor is an open collector type:
The circuit on the left will do, but wasting a bit of power every time the object moves; could use a darlington style and reduces bias current consumptions.
The circuit on the right uses a P-Mosfet which consumes practically no current if you make that pull up resistor 10M.
Everytime the sensor senses a movement, it draws current (open collector), thus turn on the bjt / P-Mos which keeps the capacitor fully charged mean while the N_Mos conducts and turn on the lamp. The N-Mos remains on, uninterrupted till the capacitor is discharged via the 10M resistor (or 1M).
RL value depends on the supply voltage and bjt/p-mos max current draw capacity so that it wont burned up
If you don't want to program, use the CD4060 circuit.
It can be reset to restart the timing cycle.
