materials or mixture
Discussion in 'Automotive Electronics' started by aanaqzzz, May 31, 2018.
  1. aanaqzzz
    Oct 11, 2017
    11
    Hi to all,
    is there's some one who knows what kind of materials use for the case mold this evaporator fan,
    its kind of ceramic?
      File size:
      278.9 KB
      22
  2. danadak
    Distinguished Member
    Mar 10, 2018
    2,614
    568
    Variant of ABS Plastic, I see a polished look to finish in a couple of
    places. Or Nylon.....
    Regard, Dana.
  3. jpanhalt
    Jan 18, 2008
    6,950
    1,453
    Have you tried a file test to see how hard it is? Take a relatively fine file for metal and see if it removes any material. If it grabs then material is below about 40 to 45 Rockwell C (HRC). I suspect many ceramics are harder than that or simply chip, not file. Reinforced plastics will file.
  4. ian field
    Oct 27, 2012
    6,503
    1,187
    ABS will crumble if you expose it to hydrocarbon solvent, acetone will fog acrylic resin - the solvent resistant stuff is probably at least part nylon.
    Ceramic is easy to spot - it will dull a file very quickly.
  5. ebp
    Feb 8, 2018
    2,332
    809
    It is too shiny to be ceramic, unless it is glazed, which seems very unlikely.
    It is likely a common polymer or blend, possibly filled or pigmented. The range of possibilities is very large, both for polymers and fillers. Since the motor is rated at just a little over 3 watts, my first guess would be acrylonitrile butadiene styrene (ABS, a blend or "alloy") which is and extremely common low-cost moderate-performance engineering plastic. It could be a more "exotic" polymer such as polyphenylene sulfide. PPS has a higher allowable service temperature than many common polymers or polymer blends, but that seems an unlikely requirement.
    https://www.samsungparts.com/DA31-00146E-EVAP-FAN-MOTOR.html
  6. aanaqzzz
    Oct 11, 2017
    11
    Actually when I try to open it, its hard like cement or like hard mixture of cholk or like a tiles inside, its just shine outside, but not a plastic
  7. aanaqzzz
    Oct 11, 2017
    11
    yes I tried to break two of this ,
    and its hard like a tile or hard mixture of cholk ,
