master's thesis
Cristopher
Joined Mar 4, 2015
19
Hello guys!
I am doing a master thesis right now. This thesis is all about measuring soil density and soil moisture content. The results will be displayed on an LCD. the block diagram is as follows:
Moisture Sensor to Controller to LCD
  • The output of the sensor is fed to the current-to-frequency converter. This frequency drives a series of comparator circuits having 3 outputs.
  • The comparator outputs are then connected to the input of microcontroller as a digital signal
  • The display of the LCD should include the soil density (g/cc) and the soil moisture content (%)
Questions:
1. How am I going to convert the digital signal from the comparator circuits into accurate measurement.
2. Do I have options other than using MicroController.
alfacliff
Joined Dec 13, 2013
2,458
a comparator for a frequency? wouldnt that be a job for digital program? a counter comparing with stored numbers. why not just pass a little dc through the soil and compare the results with analog comparator then DAC then display?
tshuck
Joined Oct 18, 2012
3,534
Presuming you are passing current through the moist soil, your results would hardly be considered accurate to begin with. There are many variables to content with, e.g. free ions, solubility of those ions, mobility, etc. How are you planning to contend with these? At best, your measurements would be able to definitively say that the conductivity of the soil has changed, and at worst, that the soil is possibly wet.
If this is not your approach, do elaborate to help us understand your approach.
Always.
#12
Questions:
How are you going to convert 3 bits of information into an accurate measurement?
I think I see your problem.
Then there is, "How an electrical signal tells about density in a substance with unknown amounts of conductive salts".
Ima think you missed a few chemistry classes.
#12
I slept from 5am to 12 noon. Seven hours is my normal sleep time.
Now...if the coffee would just kick in, I'd go fix that computer that came to the shop yesterday.
MCU88
Joined Mar 12, 2015
358
Don't forget my differential transistor-based circuit and an explanation on boost with just one diode. My life depends on this...
tshuck
Joined Oct 18, 2012
3,534
Let's keep this on topic and not harass others to remember to serve you - if he wants to, he will. If you want to send a PM, go for it, this thread isn't the place to do so.
MCU88
Joined Mar 12, 2015
358
I enjoy this forum and don't want disrespectful people to degrade my and others' experience. I don't need to be a moderator to tell you you are being disrespectful to both me and the OP.
Disrespectful? Oh get real. I would say more so being human.
Roderick Young
Joined Feb 22, 2015
408
Getting back to the original topic, I think your idea could work, and most likely there is someone already doing it. But theses need not be original. My suggestion would be to investigate how agricultural engineers measure soil moisture. Would it be through soil conductivity (that might be fair for a given soil type)? Or perhaps they put down a probe that senses humidity?
As earlier answers suggested, if you're going to use a microcontroller anyway, you can probably dispense with most of the circuitry and feed the output of the moisture sensor directly into the A/D converter of the microcontroller. Once the information is in digital form, you can compare it to whatever threshold you wish, and it will be better data than just a 3-level dry/ok/waterlogged reading. You can even use it to trigger watering if necessary. Try taking a look at the site http://www.picaxe.com/ . The PICAXE is based on the PIC microcontroller, but they've made things simple so you can just program it in BASIC. Easy to use if you don't enjoy programming, and have only simple needs. The parts are inexpensive, just a few dollars, and development software is free. And they do have A/D converter on the chip, so there's very little else that you need to add to make something work.
MikeML
5,444
Going back to the original topic, there are not good ways of measuring soil moisture content. Do some research. It has been the topic of many motivated grad. students (both agricultural and engineering students) over the years. Not much useful stuff has come out of it. I searched for a working solution for my Master Gardener wife, and could not find one...
I have supervised Masters thesis and PhD dissertation students and served on their committees. The first question during a defense are always about the scientific principles underlying the project. You can have the most elegant hardware, but if the measurement doesn't hold-up, neither will the defense...
33,074
I second MikeML's comments. While a Master's thesis does not necessarily have to bring something new and novel to the table, it does have to at least extend a body of knowledge in a useful way. To do that, you are going to have to demonstrate that your approach produces either superior results to existing technologies or that it produces comparable (perhaps even slightly inferior) results but with compensating advantages such as being significantly cheaper or not requiring as much calibration. The bottom line is that, as part of your defense, you should be able to convincingly answer the question of, "Why would someone use YOUR solution over the solutions that already exist?"
