MASTER and SLAVE PICs using SPI in Oshonsoft
camerart
Joined Feb 25, 2013
3,847
I've been trying to get 2x PICs as MASTER SLAVE for 6months now, and still not succeeded :(
As a method of testing if the SS/CS is working, can anyone tell me that if a TOGGLING LED was in the SLAVE PIC LOOP, and the MASTER PIC didn't address it, would the LED flash?
At the moment the LED on my SLAVE PIC always flashes, but I'm sure earlier I got it to stop when not addressed,
C.
camerart
Joined Feb 25, 2013
3,847
hi,
Have you written a bare bones program ie: One byte to and from the PICs pair.?
E
Hi E,
As a method of testing if the SS/CS is working, can you tell me that if a TOGGLING LED was in the SLAVE PIC LOOP, and the MASTER PIC didn't address it, would the LED flash?
Here are the 2x latest programs, plus the result of a Digital analysis:
C
camerart
Joined Feb 25, 2013
3,847
hi C,
Checking your information.
I do not see any SSPSTAT register settings/tests in either program.?
E
Hi E,
SSPSTAT has been there in past tests, but as with most settings that have been tried, this one must have been taken out.
If you add it back in, i'll test it.
(It's a bit like Eric Morcambe playing the piano :) )
Cheers, C.
ericgibbs
Joined Jan 29, 2010
21,551
hi C,
I have clipped and pasted the code from the video I posted, that show the program flow.
The top two images refer to the Master and two lower the Slave.
Assign the pins for the SPI connections as required , but keep the code uncluttered...o_O
If you create a couple of programs ie: Master and Slave using the same steps, I will go thru it with you when you post it.
E
camerart
Joined Feb 25, 2013
3,847
hi C,
E
Hi E,
Thanks.
I think it is written in ' C ' and as you know I write in Oshonsoft BASIC. Can I assume that I need to [ DIM ] variables, then add the 'SPI' PINs.
In the programs, I posted in #203 are the tops of them where I ' DIM ' the variables and TRIS the PINS suitable, if I change the other settings to you suggestions?
(Been covered in caustic soda all morning, stripping a couple of gates, good day for drying them :) )
C.
camerart
Joined Feb 25, 2013
3,847
Hi E, [ TRANSMITTER ]
SLAVE
I'm stuck on a few parts!
19F4431 doesn't accept [ ALLDIGITAL ]
OShonsoft sees [ count ] as a SYSTEM KEYWORD, is this correct or is it a VARIABLE?
I've never seen [ bytetostr ] before. I looked it up and see that it means BYTE to STRING, is it used here?
I'm not using an LCD!
Here's the program so far:
EDIT: Corrections
C
ericgibbs
Joined Jan 29, 2010
21,551
hi,
Can you tell me how you expect this code to work.?
It bears no resemblance to the sample code I posted.
E
ss = 0 'Pull ss low to select SLAVE
SSPBUF = 236 'Load DATA and begin transfer
Wend '?????????????????????????????
While(SSPSTAT.BF) 'wait till whole Byte is transfered
temp = SSPBUF 'READ what SLAVE sent in
ss = 1 'Pull SS high to terminate transfer
While(1)
camerart
Joined Feb 25, 2013
3,847
hi,
E
While(1)
Hi E,
This is what I get if I try this section of CODE literally.
C.
ericgibbs
Joined Jan 29, 2010
21,551
hi C,
That is not my code, that code is the code from the Arduino video which I clipped for you.
The code I posted was the Draft Slave code for Oshonsoft, you must convert the Arduino Master code to OS Basic.
Do you need help doing that.?
E
camerart
Joined Feb 25, 2013
3,847
hi C,
E
Hi E,
Am I correct that I use the SLAVE DRAFT.TXT as a guide for both programs, but use the [ SPI_Basic1.gif ] for each of the settings?
If this is correct I'll have a go first, thanks.
C.
ericgibbs
Joined Jan 29, 2010
21,551
hi C,
I named it SLAVE DRAFT.TXT in order to make it clear it was intended as a guide for the Slave PIC.
The MASTER.TXT program code must be different as it is the controlling PIC, it decides when it wants to exchange data with the Slave.
If you want the Slave to tell the Master 'I have data in my SSBUF and I am ready for data exchange ' the Slave would pull a Slave to Master I/O line Hi, [not one one of the SPI lines.] and wait for the Master.
E
Note:
The Arduino While(!BF)
is Osh
While NOT SSPSTAT.BF Wend ' it reads and loops for all 8 bits of the data exchange Byte
camerart
Joined Feb 25, 2013
3,847
hi C,
E
Note:
is Osh
Hi E,
Is this better?
C
ericgibbs
Joined Jan 29, 2010
21,551
ho,
Look at this amendment of your code.
Note: this compiles, but it is only the very basic code, you need to add all the supporting code for the program in order for it to do any work.
E
