Managing LCD with pic
JridiHamza
Joined Jul 22, 2014
18
Hi everyone
I want to manage 2 LCD displays with 1 pic microcontroller
I want to know how to write in each one a different message,anyone can help me on this plz
note: I use CCS c compiler
shteii01
Joined Feb 19, 2010
4,644
Connect one lcd to one port, connect second lcd to another port. Copy the lcd program from one of the tutorials, modify it to send messages to either one of the lcd.
JridiHamza
Joined Jul 22, 2014
18
I did that but I didn't know how chose the lcd that I want to display on it the message
that's my program for one lcd
#include <lcd.h>
#use delay(clock=20000000)
#fuses HS,NOWDT,NOPROTECT,NOPUT, NOBROWNOUT,NOLVP
#define LCD_ENABLE_PIN PIN_A0
#define LCD_RS_PIN PIN_A2
#define LCD_RW_PIN PIN_A1
#define LCD_DATA4 PIN_C4
#define LCD_DATA5 PIN_C5
#define LCD_DATA6 PIN_C6
#define LCD_DATA7 PIN_C7
#include <lcd.c>
#define use_portc_lcd TRUE
void display_ES(void)
while(true)
lcd_init();
lcd_putc("message1"); }}
30,808
The input impedance is usually fairly high, you may be able to parallel the data buses to one port and use separate control , E, RS, RW signals.
JohnInTX
Joined Jun 26, 2012
4,787
You use two separate Enable signals. That is what MrChips already told you.
Except that if you use the compiler's libraries, you don't have that option. It's designed to support one enable only.
You could write your own LCD routines or use some external logic to route the ENABLE signal to one of the two displays according to an additional output that you manually select before using any library routine. If you go this route, you'll have to select one display, run lcd_init() then select the other and run lcd_init() again. Any subsequent writes would be preceded by selecting the target display. Other than that, what the others have indicated is perfectly workable.
35,168
No, that wouldn't work. You cannot use the lcd_putc() library function.
That is what you get for using library functions.
Learn to write your own functions. It's not difficult.
JridiHamza
Joined Jul 22, 2014
18
how do I chose the target display that's my biggest problem???
JohnInTX
Joined Jun 26, 2012
4,787
Like the others, I'd write my own routines but if you want to try the libraries, this external selector should work.
Set the new output port to route ENABLE to the desired display, then write away.
Have fun.
EDIT Don't forget to pull the ENABLE down at the PIC with a 10K-68K resistor to avoid spurious enables during RESET.
THE_RB
Joined Feb 11, 2008
5,438
Did you read the other posts in this thread? :)
As another method (expanding on JohnTX's idea), it can be done with the library code, if you don't mind sacrificing two more port pins.
Connect the PIC E output pin to each LCD E input through a 2k2 resistor. Then connect two more PIC pins, one to each LCD E pin;
* If one of those PIC pins is grounded and an output pin that E signal will not work.
* If the PIC pin is switched to high impedance (an input) then that E pin will work.
That will allow you to set those two pins as needed, then use the library LCD functions. Total cost 2 pins and two resistors. :)
JridiHamza
Joined Jul 22, 2014
18
Have fun.
this is the shemas bloc and my code but it doesn't work
can you tell me what's rong plz??
#include <lcd.h>
#define LCD_ENABLE_PIN PIN_A2
#define LCD_ENABLE_PIN PIN_B7
#define LCD_RS_PIN PIN_A0
#include <lcd.c>
void main()
lcd_init();
while(TRUE)
output_low(pin_b7);
lcd_putc("message 1");
output_high(pin_b7);
lcd_putc("message 2");//TODO: User Code
35,168
You now have three suggestions for interfacing two LCD modules:
1) MrChips - Write your own LCD functions, requires one additional pin.
2) JohnInTX - Use library functions, requires one additional pin and external gates.
3) THE_RB - Use library functions, requires two additional pins and two resistors.
The solution provided by THE_RB requires the least amount of effort.
You cannot use two defines such as:
Learn how the #define preprocessor directive works.
Leave LCD_ENABLE_PIN as
Now you have to create two new constants:
#define LCD_ENABLE1 PIN_A2
#define LCD_ENABLE2 PIN_B7
Before you call any LCD library functions, call a LCD select function such as:
LCD_Select1();
or
LCD_Select2();
Here is the pseudo code for the two functions:
Rich (BB code):
void LCD_Select1(void)
   // output logic LOW to LCD_ENABLE2
   // configure LCD_ENABLE1 as input
void LCD_Select2(void)
   // output logic LOW to LCD_ENABLE1
   // configure LCD_ENABLE2 as input
If you have wired your circuit using the solution provided by JohnInTX, you can still use the scheme outlined above. Modify the functions to control the selection of the E signal to the desired LCD module.
Here is the pseudo code for this:
Rich (BB code):
   // output logic HIGH to LCD_ENABLE1
JohnInTX
Joined Jun 26, 2012
4,787
Per the OP's PM, some clarifications for the external gate method. In this case the new pin is a selector so name it that way. The display designations match my original sketch.
Rich (BB code):
#define LCD_SELECT PIN_B7  //name the selector pin 'SELECT'
void LCD_Select0(void)
   // output logic LOW to LCD_SELECT
 LCD_SELECT = 0;
   // output logic HIGH to LCD_SELECT
 LCD_SELECT = 1;
On the schematic, the single pull-down resistor should be on the PIC pin (RB7), not the output of the gates. Its purpose is to hold E at '0' when the PIC is coming out of reset before initializing the PIC's I/O ports. You don't need/want the push buttons on the gate outputs.
Don't forget to complete the hardware connections to the display (Vdd, Vss, VEE etc.)
Your code does not show any initialization of PIC IO i.e. setting up TRIS, ADCONx, etc. You have to do that in any case.
As MrChips says, for either of the LCD_Selectx() hardware methods you'll have to select the desired display before ANY write to the LCD, including init.
Rich (BB code):
void init_Displays(void)
 LCD_Select0();
 lcd_init();
 lcd_putc("0 Initialized");
 LCD_Select1();
 lcd_init();
 lcd_putc("1 Initialized");
Note that if you use RB's clever solution, the logic selecting then writing the LCD is the same, just the LCD_Select routines are different. MrChips shows how its done.
35,168
You can also do this:
Rich (BB code):
void LCD_Select(char LCD)
   if (LCD)
        LCD_SELECT = 1;
   else
        LCD_SELECT = 0;
Now you can call
LCD_Select(LCD0);
or
LCD_Select(LCD1);
if
#define LCD0 0
#define LCD1 1
or you may prefer:
LCD_Select(0);
LCD_Select(1);
