Managing LCD with pic
JridiHamza
Joined Jul 22, 2014
18
Thnaks to all of you guys it works very well now :)
Rich (BB code):
#include <main.h>
#use delay(clock=20000000)
#fuses HS,NOWDT,NOPROTECT,NOPUT, NOBROWNOUT,NOLVP
#define LCD_ENABLE_PIN PIN_A2
#define LCD_RS_PIN PIN_A0
#define LCD_RW_PIN PIN_A1
#define LCD_DATA4 PIN_c4
#define LCD_DATA5 PIN_C5
#define LCD_DATA6 PIN_C6
#define LCD_DATA7 PIN_C7
#include <lcd.c>
#define LCD_SELECT PIN_B7  //name the selector pin 'SELECT'
void LCD_Select1(void)
   // output logic LOW to LCD_SELECT
 //LCD_SELECT = 0;
 output_low(pin_B7);
void LCD_Select2(void)
   // output logic HIGH to LCD_SELECT
 //LCD_SELECT = 1;
 output_high(pin_B7);
void init_Displays(void)
 LCD_Select1();
 lcd_init();
 lcd_putc("1 Initialized");
 LCD_Select2();
 lcd_init();
 lcd_putc("2 Initialized");
void Display(void)
 LCD_Select1();
 lcd_init();
 lcd_putc("Message 1");
 LCD_Select2();
 lcd_init();
 lcd_putc("Message 2");
void main()
init_displays();
delay_ms(3000);
   while(TRUE)
     display();
JohnInTX
Joined Jun 26, 2012
4,787
And nothing succeeds like success. Well done!
What's the push button for on the ENABLE line?
EDIT: Since you are early in the development, consider trying some of the other methods described in the thread. Anytime you can eliminate some hardware c.f. RB's two resistors, its a good thing. You always have the working one to come back to.
JridiHamza
Joined Jul 22, 2014
18
thnx bro :)
fot the push button I used to use the pull down resistor on that way for leds e.g but I understand now that it's a mistake :)
35,159
It's all a collaborative group effort. And the best part is the advice is free. That's what I like about AAC.
Pat yourself on the back.
