What is wrong with this one ?
If you have a close look it has the side missing.What is wrong with this one ?
Im going to need more info for the resistor value and what I can replace it with.Looks like 0.47 ohms 5%.
So if I replace the resistor is there going to be a high chance that something else is causing this and it will fail again??If it blew, then there should be a reason. Low value R just don't blow for fun. It's a protection resistor of sort. I believe.
Oh ok R!f@ did say that could be the problem also.The PSU chip starting with "MIP" could be the issue.
Fuse is good.How is the fuse ?
What part of the board do you need better pics of??Show me pictures of the problem PSU.
Which cap is the main filter one? Is that the C203?Need to check the capacitance of the main filter cap
So is the stby the IC102 chip which is the MIP?stby PSU chip.
