Hello. I would like some light bulbs for my room that are a warm orange-white when dimmed, but shift to a neutral white when pushed to full brightness.
Fortunately, there is already a product on the market like this; Philips Warm Glow. The problem that I have with these is that they are quite warm-coloured even at full brightness. The colour temperature only shifts from 2200K to 2700K. I want it to start at 1800-2300K and shift to 3500-4200K at full brightness.
I don't know how Philips achieves this, or what power LED's they use as components. Are there LED's that naturally shift colour based on current? But my idea to get this effect is to wire a set of orange-white LED's in parallel with a set of neutral white LED's (or even cool white). The orange-white LED's would be linked in series with a small resistor, and the whole series would have a lower voltage drop than the set of neutral white LED's. This way, they would turn on at a lower voltage, but have less brightness at full voltage than the neutral-white LED's.
I can get some LED bulb kits on Toolboom and change the LED's, or I can buy the LED driver and LED housings separately. Although they don't include any curcuit diagrams, I figure that the aluminium PCB's for the 5730 LED's have the LED's wired for two parallel series. The reason I think is because their LED driver has a max current output of 300mA, and the 5730 LED has a 150mA maximum rating. They all have even numbers of LED's. However, it should be possible to change the circuit if I don't connect the + & - leads in the intended places.
Does anyone see any issues with my plan, or have some advice?
