Making foot switch for router for woodworking
iFunk
Joined Apr 6, 2018
11
Hi there, I'm new to this forum, so hello. I have a quick question, I'm in the UK by the way: I am making a pedal switch for a friend for his router to make life easier. I got a footwsitch off of ebay a while ago, the actual switch inside is rated for 15A and 250V so should be fine for UK power. So What I have done is make up a short extension cable, just 1 meter and in the middle of the cable, I've just cut the live wire put cable into junction box, and off the now two ends of the live added the cable that just goes to the push to make switch.
Do I need a capacitor across that switch to smooth the power delivery or does it not matter that much with power tools. If so, what type of capacitor and rating would be the best to use?
ericgibbs
Joined Jan 29, 2010
21,568
hi iFunk,
Welcome to AAC.
You could connect a 'snubber' across the switch contacts.
That is a 100 Ohm resister in series with a 100nF capacitor.
It is important that the capacitor is suitable for mains operation.
E
iFunk
Joined Apr 6, 2018
11
Hi ericgibbs, thanks for your reply, thank you, new word 'snubber' was exactly what I needed, that's awesome, just found lots of info on that, thanks very much.
MaxHeadRoom
Joined Jul 18, 2013
30,808
I'm in the UK by the way: So What I have done is make up a short extension cable, just 1 meter and in the middle of the cable, I've just cut the live wire put cable into junction box, and off the now two ends of the live added the cable that just goes to the push to make switch.
Don't forget the earth wire to the foot pedal frame if metallic cover/case.
Max.
iFunk
Joined Apr 6, 2018
11
Ah ok, so considering that I am using a push to make switch, not a toggle on off switch. Basically my friend does wood work and so the router that he uses has a switch in an awkward position, so he will be switching it on, then using the footswitch to take the power from the mains. Do you think it's ok without? It won't shorten the life of the router? for me it's a lot easier without, but I'm new to power electronics really.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Do you think it's ok without? It won't shorten the life of the router? .
A snubber across the switch is more for it than the router, there can be quite the arc when breaking motor loads such as these, if you can fit it in, it may save the switch from premature failure.
Max.
iFunk
Joined Apr 6, 2018
11
I think I'd like to put one in, I have a junction box that takes the live feed from the extension cable so there is plenty of space. Thank you all for you help, this is an awesome forum!
iFunk
Joined Apr 6, 2018
11
So I have a snubber component, but data sheet doesn't tell polarity, how can I check this so i don't blow the cap in it? I have included the datasheet the one I have is the bottom one.
iFunk
Joined Apr 6, 2018
11
Yes, I would have expected the resistor part first, the problem is there is nothing on the component or in the data sheet to show which way round it is, is this just a bad data sheet or is it because the component is not polarised? If it is how could I test it to see which lead is attached to what?
ericgibbs
Joined Jan 29, 2010
21,568
Its not polarised, so its orientation does not matter.
Most times if you read a circuit diagram the resistor would be connected to live.
Just convention.
E
