Making cheap stereo. Do i need ground?
str1fe
Joined Feb 19, 2018
Hi, i just bought a cheap amplifier board from ebay, and a power supply (24v). After connecting the wires i started wondering if i need to connect the earth cable. My power input cable has only two wires, and no ground, but the power supply have a ground input.
The power supply looks almost like this in the front (sorry did not take pictures before i closed the box). I connected only to N and L, but not ground.
Do i need to have ground connected, is there some chance of danger if i do not connect it? Many of my wall sockets does not have ground in them
MaxHeadRoom
Joined Jul 18, 2013
30,808
I seem to recall Norway has mainly 220v L & N but rarely grounded sockets, If using it this way , I would ensure the whole system is enclosed in a non metallic enclosure.
Max.
paulktreg
Joined Jun 2, 2008
851
Your power supply isn't double insulated and includes an earth connection that should be connected.
However I see there are Type C (No earth) and Type F (Earth available) sockets in use in Norway. Connect the earth if you can or follow the advice of Max.
str1fe
Joined Feb 19, 2018
Alright, thank you!
There are some knobs on the amp board which are made of metal, and the speaker connectors, otherwise the enclosure is made of mdf wood material. Perhaps i should attempt to cover up some of it with some epoxy silicone like sugru, to protect me.
