Making a N.C. reed switch functio as a N.O. switch
iONic
Joined Nov 16, 2007
1,662
Was wireing some LED lighting under my sink cabinets and seem to have bought the wrong reed relays. They are CLOSED(current flowing) when they are in proximity to one another(when cabinet door is closed, and OPEN when the cabinet door is open...............resulting in the LED's being ON when the cabinet door is closed and off when the door is open.
No, they are not configurable for N.C. or N.O.
If there any other way to get the functionality that I need from these switcher.....additional parts??
Just thought I'd ask before I send them back. It was hard to find them at a reasonable price, and these did fit the bill with this respect.
MaxHeadRoom
Joined Jul 18, 2013
30,750
A small relay would do it.
What current do they switch as there are relays as small in a 8pin DIP package.
Probabally easier to source N.O. reed SW's.
Max.
Reloadron
Joined Jan 15, 2015
7,893
Yes but I doubt the ends would justify the means in that you would be adding more circuitry. I see Max posted as well as Albert and I would agree the best solution would be to just get new switches suitable for the load.
Ron
ebp
Joined Feb 8, 2018
2,332
A reed switch that is normally closed very likely has a biasing magnet "attached." If the magnet can be removed, it will become normally open, however everything is likely potted and inaccessible.
EDIT - if it is magnetically biased to be normally closed, it may be possible to make it normally open by reversing the field direction of the external magnet - which again may be pretty much impossible in any practical way
Reloadron
Joined Jan 15, 2015
7,893
I can buy a 2 pack of NC / NO reed switches for about $16.50 USD on Amazon Prime and get them in two days. That includes the magnet assemblies and the switches are enclosed. Not mentioned is the current ratings? I also don't know what your LED current requirement is? The bottom of the linked page has a wide variety of similar switches for less cost. Most are rated for 0.5 Amp (500 mA). How many were you needing to get?
I have used the Hamlin versions that are made for this application, the 59135 series, they have N.O/N.C. versions.
Max.
The Hamlin stuff is really good stuff and I have also used them with great results.
Ron
iONic
Joined Nov 16, 2007
1,662
Yeh, the addition of additional circuitry to rectify a mistake is surely a fools errand, especially when the install is not yet complete and it would not take that much effort to get the right parts.
These are 20mA, 12V LED's, so in general the most current that will flow even if all doors are open would be ~160mA
(Current resistors are part of the LED pkg. 130 Ohm)
Reloadron
Joined Jan 15, 2015
7,893
You want N/C so the proximity of a magnet opens the switch. The magnet proximity is present when the cabinet is closed so the N/C switch is open but when the cabinet is opened, magnetic field removed, the switch will close. Think about it. :) As drawn the switches have no magnetic field present but when the cabinet is closed the magnet is beside the switch and the switches will close, not what you want.
Something I forgot to mention is you may find reed switches at any home improvement store like Lowes or Home Depot in the US.
Now what bothers me is how do I know that when I close my refrigerator the light really does go out?
Ron
LesJones
Joined Jan 8, 2017
4,509
You could use a small power mosfet. If you use an N channel device connect the source to the supply negative. Connect the load (LED string.) between the drain and positive supply. connect a high value resistor (100K for example.) between the gate and positive supply. Connect the NO reed switch between the gate and source. When the switch was open the gate would be biased to the positive rail cauing the mosfet to conduct. When the reed switch was closed it would short the gate to the source which would stop the mosfet from conducting. These would be a small current flowing through the resistor when the reed switch was closed. With a 12 volt supply and a 100K resistor the current would be 120 uA.
Les.
AnalogKid
Joined Aug 1, 2013
12,210
From your schematic it looks like 40 mA per switch. One 2N7000 MOSFET and one 10K resistor per switch will invert (door open = on) the power drive to the LEDs, about $1 for all 4 circuits.
ak
iONic
Joined Nov 16, 2007
1,662
Ron
We may have to disagree on this point.
Where I think we deviate is that I am considering the "switch" is both the reed switch and magnet.
Reloadron
Joined Jan 15, 2015
7,893
:) No problem as long as you know what you want it to do. I see the state as the normal state of the switch less it being activated by the magnet. Long as it does what you want life is good. :)
Ron
iONic
Joined Nov 16, 2007
1,662
Les.
@AnalogKid @LesJones
So, let me get this straight.
Provided I rewired the circuit right in the schematic bellow.
When the cabinet door is closed, the reed switch is closed, causing a short from Gate-Source, which in turn blocks current flow through the LED's & Drain-Source. When I open the cabinet door, the reed switch opens and removes the short between G-S, allowing the MOSFET to be turned on and allowing the LED's to turn on via current through D-S.
Really just trying to figure out the simplest place to cut wires to add these components without making a web of wires. I also need to calculate the KWH of power consumption of this active MOSFET to determine if this method is a game-changer!!!!!
LesJones
Joined Jan 8, 2017
4,509
You say in post #10 that the LEDs are rated at 20 mA but you also say that they have a built in 130 ohm resistor. Assuming that these are white LEDs their forward voltage will be about 3.3 volts which means there will be 8.7 volts across the 130 ohm resistors so he current through the LEDs will be 8.7/130 = 67 mA which is more than 3 times their current rating
If you use 100K resistors to the mosfet gates while the doors are closed (LEDs off.) it will consume 0.038 KWH per year. ( It would be 0.38 KWH per year if you use 10K resistors.) Both of those values would probably be less than the loss in the 12 volt power supply.
Les.
AnalogKid
Joined Aug 1, 2013
12,210
Your understanding of the circuit is correct.
The value of R1 is a tradeoff between static, off-state current consumption, and noise immunity. The smaller the R, the better the immunity and the higher the power dissipation. For me, I'd use something in the 1.5K - 10K range. 1.5K or more keeps the power dissipation below 0.1 W, a good value for long term reliability of a 1.4-W resistor; and 10K or less reduces the circuit impedance for improved noise immunity. If the 12 Vdc source is AC line powered (as opposed to batteries), I'd go with 2.2 K.
ak
