So, now i have been playing a little, and now i will say it's finished
See what u think of it,
I works well, but need to change from RC4 to RC7, couse somehow the RC4 stayed "low" from pressed until power loos.
Works ok with RC7.
Rich (BB code):
#include <htc.h>
//#include <stdio.h>
#include <stdlib.h>
#include "lcd.h"
__CONFIG (FCMEN_ON & IESO_OFF & BOREN_OFF & CPD_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTRCIO);
#define LED RC0
#define set_hour RC7
#define set_minut RC5
#define set_week RC6
#define set_time RC3
#define _XTAL_FREQ 4000000
//global defs
volatile unsigned char week_day;
volatile unsigned char hour, minut, sec, x, xx, y, i, sel;
volatile bit minut_tick, set_time_flag,regn_tick ;
volatile bit blink;
volatile int mm;
char timestr[3], regn[4], idag[4];
const char * const day_of_week_names[] = {"Mandag ",
"Tirsdag",
"Onsdag ",
"Torsdag",
"Fredag ",
"Lordag ",
"Sondag "
static void interrupt
isr(void) // Here is interrupt function - the name is unimportant.
if(TMR1IF)
{// Was this a timer overflow?
TMR1IF=0;//Clear interrupt flag, ready for next
TMR1H=0x80;
//If we set TMR1 to start at 0x8000 (32768), the TMR1 will overflow every 1 second
regn_tick=1;
blink=!blink;
LED=blink;
sec++;
if (sec==5)
minut_tick=1;
sec=0;
void sluk_ur (void)
set_time_flag=1;
GIE = 0; // Global interrupt disable as we are setting the time
TMR1ON=0; //timer1 off
sec=0;
TMR1H=0x80;
TMR1L=0;
LED=1;
void start_ur (void)
GIE = 1; // Global interrupt enable
TMR1ON=1; //timer1 on
set_time_flag=0;
void setup(void)
{ TRISA0=0;
TRISA2=1;
TRISC=0b11111000;//RC0-RC2 out,RC3-RC6 in,RC7 in
TRISB=0; //All port B output
GIE = 0; // Global interrupt disable just in case
ANSEL=0;
ANSELH=0;//turn off all analog functions
//timer1 settings
TMR1H=0x80;
TMR1L=0;
//T1CON=0b00000110;//used during debug
T1CON=0b00001110;
// See datasheet REGISTER 6-1: T1CON: TIMER 1 CONTROL REGISTER
// bit order T1GINV TMR1GE T1CKPS1 T1CKPS0 T1OSCEN !T1SYNC TMR1CS TMR1ON
//Timer1 Interrupt prepare
TMR1IE=1;// PIE1 register
PEIE=1; //INTCON register
PIR1=0; // Clear all bits PERIPHERAL INTERRUPT REQUEST REGISTER 1
//todo now in order to generate interrupt GEI=1 and TMR1ON=1
//timer0 settings.
//INTCON=0b01100000;
//setup LCD
lcd_init();
lcd_goto(0); // select first line
//set the globals
week_day=5;
minut=0;
sec=0;
hour=0;
minut_tick=0;
blink=0;
TMR0=eeprom_read(31);
//regn_tick=0;//clear the tick
void lcd_tiden(void)
lcd_clear();
lcd_goto(0x00);
lcd_puts("Klokken er : ");
utoa(timestr, hour, 10);
if (hour<10)lcd_puts("0");
lcd_puts(timestr);
lcd_puts(":");
utoa(timestr, minut, 10);
if (minut<10)lcd_puts("0");
lcd_puts(timestr);
lcd_goto(0x40); // Select second line
lcd_puts("Dagen er : ");
for (unsigned char i=0;i<7;i++) lcd_putch(day_of_week_names[week_day]);
lcd_goto(0x00);
void reset (void)
lcd_clear();
lcd_goto(0x04);
lcd_puts("Slet total ?");
lcd_goto(0x45);
lcd_puts("JA / NEJ ");
lcd_goto(0x00);
x=0;
while (x<100)
if (!set_week)
{TMR0=0;
eeprom_write(31,0);
eeprom_write(32,0);
lcd_clear();
lcd_goto(0x06);
lcd_puts("Slettet !");
lcd_goto(0x00);
__delay_ms(1000);
x=99;
if(!set_minut)x=0;
x++;
__delay_ms(100);
void vis_regn (void)
if (mm<TMR0)
lcd_clear();
lcd_goto(0x00);
lcd_puts("Regn Total : ");
if (TMR0<100)lcd_puts(" ");
if (TMR0<10)lcd_puts(" ");
utoa(regn, TMR0, 10);
lcd_puts(regn);
lcd_puts(" MM");
eeprom_write(31,TMR0);
lcd_goto(0x40);
lcd_puts("Regn ");
lcd_puts(": ");
x= eeprom_read(32);
xx=TMR0-x;
if (xx<100)lcd_puts(" ");
if (xx<10)lcd_puts(" ");
utoa(idag, xx, 10);
lcd_puts(idag);
lcd_puts(" MM");
lcd_goto(0x00);
mm= atoi(regn);
void select (void)
sel=1;
x=0;
__delay_ms(100);
while (x<70)
if (!set_hour)
{ lcd_goto(0x40);
lcd_puts("Regn dag -");
lcd_goto(0x4a);
if (sel<10)lcd_puts(" ");
utoa(regn, sel, 10);
lcd_puts(regn);
lcd_goto(0x4c);
lcd_puts(" :");
y=eeprom_read(sel-1);
if (y<100)lcd_puts(" ");
if (y<10)lcd_puts(" ");
utoa(regn, y, 10);
lcd_puts(regn);
lcd_puts(" MM");
sel++;
x=0;
if (sel==31)sel=1;
__delay_ms(255);
__delay_ms(100);
x++;
lcd_goto(0x00);
mm=-1;
vis_regn();
void midnat (void)
week_day++;
if (week_day==7) week_day=0;
x=eeprom_read(31);
eeprom_write(32,x);
i=0;
while (i<30)
x=eeprom_read(i+1);
eeprom_write(i,x);
i++;
mm=-1;
vis_regn();
void ur (void)
minut++;
if (minut>=60)
{ minut=0;
hour++;
if (hour>=24)
{ hour=0;
midnat();
void stil_ur (void)
sluk_ur();
lcd_tiden();
do
if (!set_hour)
hour++;
if (hour==24) hour=0;
lcd_tiden();
__delay_ms(200);
if (!set_minut)
minut++;
if (minut==60) minut=0;
lcd_tiden();
__delay_ms(200);
if (!set_week)
week_day++;
lcd_tiden();
__delay_ms(200);
} while (!set_time);
start_ur();
mm=-1;
vis_regn();
void main (void) //hovedprogram
setup();
mm=-1;
timestr[2]='\0';
vis_regn();
GIE=1;
TMR1ON=1;
mm=-1;
while (1)
if (minut_tick)
ur();
minut_tick=0;
} // (minut_tick)
if (regn_tick)
vis_regn();
if (!set_time)
stil_ur();
if (!set_week)
{lcd_tiden();
x=0;
while (x<100)
{if (!set_week)x=0;
__delay_ms(100);
x++;
mm=-1;
if(!set_hour)
select();
if (!set_minut)
{reset();
mm=-1;
vis_regn();
// flere hvis.....
//end while endless loop
//End main
Works ok with RC7.
