LVDS Spec - not enough information?
matthej
Joined Oct 10, 2020
68
I am looking at a specification for an LVDS clock oscillator. The specification is below. As you can see there is no mention of common mode voltage or voltage swing, only Voh and Vol levels. Don't I need more information that what is in the datasheet?
If I take the Voh at 1.6V and Vol at .9V, my voltage swing would be 700mV, but what is the smallest voltage swing? My receiver is expecting a 100-600mV
KeithWalker
Joined Jul 10, 2017
3,615
The spec sheet gives you the absolute limits of the spread of the output logic levels. What more do you need? If you want larger signals, use a digital buffer/amplifier on the output or a different clock chip.
matthej
Joined Oct 10, 2020
68
No mention of common mode voltage.
Do I assume the spread then can be 700mV?
KeithWalker
Joined Jul 10, 2017
3,615
The single output is logic level digital pulses. Why do you need common mode voltages? Use a logic level shifter to match it to your receiver.
KeithWalker
Joined Jul 10, 2017
3,615
On second thoughts, maybe you have picked the wrong type of crystal oscillator. They are available with either digital or analog signal output. What is the full requirement of your receiver clock input?
matthej
Joined Oct 10, 2020
68
This is a differential signal. The receiver is expecting a certain common mode voltage for it to work properly. Not sure what to level shift to if I don't know where the signal is at
KeithWalker
Joined Jul 10, 2017
3,615
Does the receiver require digital pulses or an analog sine-wave input?
