LTSpice, Reading values from plot
SpiderRico
Joined Mar 8, 2014
6
Hello all,
When I run a simulation on LTSpice it generates a graph. By doing File->Export I can get the numerical values in a text file. However this doesn't help me much.
For example I want to find the crossing point of Vout and Vin. I see they cross at some point in graph but can't tell exact value by looking at it. Is there a way for me to print that value ?
ericgibbs
Joined Jan 29, 2010
21,637
hi,
After you have plotted the graphs, place your cursor on the crossing point on the graph.
Look at the bottom left of the LTS window at the Status bar, it will display the values under the cursor pointer as you move the cursor.
E
Post your *.asc file and I will explain further.
38,929
After you have plotted the waveform you can also click on the waveform node-title at the top of the graph to generate a cursor that you can move along the graph. If you double-click then you will get two cursors which will give the absolute value at each cursor position and the difference between the two cursor positions.
SpiderRico
Joined Mar 8, 2014
6
No I mean I know how to measure the delay by hand but I ask if there is a way for simulator to derive it or do I have to find the values from the simulator and then plug them in the formula and calculate by hand ?
38,929
As I previously noted, if you double click on a waveform title you will get two cursors. Move each of the two cursors to the points you want to measure. The cursor box will then give you the time difference between the two cursors.
SpiderRico
Joined Mar 8, 2014
6
Okay, perhaps my question wasn't clear. I've got 2 tasks and and I'll try describing them as clear as I can. Any help is much appreciated.
In LTSPICE, I've built a pseudo-NMOS inverter.
1) I've a initial guess for Wn value of NMOS. I start the simulation with this value however, I need to optimize it and get a more precise value.
Basically, when Vol < x for some x, I need to find the minimum Wn value that satisfies this inequality.
2)Initially, nothing is connected to the output of inverter. Then, I connect a capacitor after finding my Wn value. At this point I need to find LOW-to-HIGH delay of the inverter.
SpiderRico
Joined Mar 8, 2014
6
I guess if I can set Wn as a parameter then I can just find its value in graph. I tried right-clicking my NMOS and writing {x} in box but it didn't work.
