ltspice - op amp astable multivibrator square wave.
jackmrdoctor
Joined Apr 17, 2018
16
i have a problem to run a op amp astable multivibrator square on lt spice. the graph should square wave with a duty cycle 50 percent. i already found a similar problem on internet but i stil can not figure it out. pls help me.
Ylli
Joined Nov 13, 2015
1,092
Lower voltage source is specified as -15 volts, and you are using the - pin as hot. That means you have +15 volts on both power pins of the op-amp. Change V2 to +15 volts and you should be good to go. Do note that the period of the output is about 12 ms and you are only looking at 10 ms of time. Bump that up to at least 25 ms.
