LTSpice: my retro power supply now with current limit
Sjöholm
Joined Jun 13, 2018
35
Hejsan everybody!
I want to implement some current limiting on my retro power supply before I kickstart my kickstarter campaign, so I came up with this design that sort of works. I'm not sure I'm setting the current limit at the smartest point in the circuit R5, but that's what I've chosen so far. The only concern I have is that for R5 values below ~2k the thing seems to want to oscillate, so I put two caps C1 and C2 in the circuit and that helped on the oscillation, but now the sim runs kind of slow. I would appreciate you comments, thank you all. Again I'm aiming for 0-30V 5A or so as a minimum for the whole contraption.
Alec_t
Joined Sep 17, 2013
15,167
As above. The circuit does seem overly-complicated. Low-side current-sensing would save on a few components.
