Ltspice MAXIMUMPEAK-TO-PEAKOUTPUT VOLTAGEVERSUSFREQUENCY graph
Arda_T
Joined Oct 13, 2025
I tried to make the graph of peak to peak output voltage vs input frequency for a custom designed opamp but the issue is when you use ac anaylsis it operates as small-signal so it does not care about rails. I intended to create such a graph belowresim_2025-10-13_173922780.png
WBahn
Joined Mar 31, 2012
33,171
I tried to make the graph of peak to peak output voltage vs input frequency for a custom designed opamp but the issue is when you use ac anaylsis it operates as small-signal so it does not care about rails. I intended to create such a graph belowView attachment 357091
I would imagine that a dominant factor in that graph is the effect of the maximum slew rate.
