I've received a model file for a Depletion mode, n-channel MOSFET from Microchip and imported it into my LTSpice circuit in the easiest way possible- basically copy and paste the .model file into LTSpice and then change the MOSFET's name to LND01 (the MOSFET type). See .txt file attached
I used the symbol "N-Channel MOSFET Transistor with explicit substrate" connection because the BODY needs to connect to the GATE, not the Drain. However whether I actually change the name of the MOSFET to LND01 or leave it at the standard NMOS, I'm getting the same simulation. (See attached .asc file)
Not sure if I'm importing the file incorrectly or the file doesn't work with LTSpice? I've read everything on the topic and not sure where to go from here...
any help would be great! Thank you!
