Import LTSpice model from external library
kalemaxon89
Joined Oct 12, 2022
389
I tried importing the ISC022N10NM6 present in OptiMOS6_100V_LTSpice.lib and autogenerated a symbol.
I followed this procedure:
1) I put in LTSpice sub folder il file OptiMOS6_100V_LTSpice
2) I drag it into LTSpice, select .SUBCKT ISC022N10NM6 drain gate source Tj Tcase PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Zthtype=0 Ls=250p Ld=100p Lg=2.2n and create symbol (self-generated)
Before I start using it, I would like to see if I imported it well and if it works. Since it is a mosfet, I would like to recreate its Vds-Id characteristic curve:
Simulating, I get this:
Am I doing something wrong in the simulation?
Or did I import the component wrongly?
