LTspice - How to subtract two .meas variables?
Kevil
Joined Jun 28, 2020
224
I am simulating band pass filter and would like to calculate the bandwidth.
Code:
.meas Vmax MAX (mag(V(vout)))
.meas AC f1 FROM 0 TARG mag(V(vout))=Vmax/sqrt(2) RISE=1
.meas AC f2 FROM 0 TARG mag(V(vout))=Vmax/sqrt(2) FALL=1
vmax: MAX(mag(v(vout)))=(37.891dB,0°) FROM 1.4e+009 TO 1.8e+009
f1=1.55052e+009 FROM 0 TO 1.55052e+009
f2=1.60742e+009 FROM 0 TO 1.60742e+009
How to calculate bw = f2 - f1 by LTspice command? It would be nice to format result e.g. "bw=56.9Meg" or "bw=56.9e+6"
Papabravo
Joined Feb 24, 2006
22,113
Here is an example of finding the peak of a narrow band Twin-Tee filter. Change the (1+epsilon) expression to SQRT(2) and it will find the -3 dB points on a magnitude plot.
eetech00
Joined Jun 8, 2013
4,730
Code:
This is right out of LTspice "help" for .meas:
.MEAS AC tmp max mag(V(out))
.MEAS AC BW trig mag(V(out))=tmp/sqrt(2) rise=1 targ mag(V(out))=tmp/sqrt(2) fall=last
BW measurement at -3dB from 0dB
(It was a little difficult pointing in the graph with the mouse but I think you get the idea) :)
Kevil
Joined Jun 28, 2020
224
Thank you, it's working well.
By the way how to display the frequency ?
e.g. vmax: MAX(mag(v(vout)))=(37.891dB,0° at 1.5536084GHz)
Papabravo
Joined Feb 24, 2006
22,113
The results of the .meas directives are written into the Spice Error Log which you can access with the "View" menu
So left click View | Spice Error Log or use keyboard Alt-V, then L
Error Log will be displayed in a separate window
Select the appropriate text from the Spice Error Log
Paste it into a comment text box and place it on the schematic
See the schematic in Post #2 where the values of temp and bw are lines 4 & 5 underneath the title
Kevil
Joined Jun 28, 2020
224
I know the Spice Error Log where to look for measured values ;).
I raised another problem see above:
How to display the frequency ?
Papabravo
Joined Feb 24, 2006
22,113
You're right, I haven't got the faintest idea what you are asking. Maybe there is somebody else who understands you better. I do know that the syntax of the .meas statement can choose between the quantities normally displayed in the waveform viewer on the vertical axis ang quantities that are normally on the horizontal axis like time an frequency. You have an example, using the keywords TRIG and TARG to display the bandwidth of a filter. There is also my example of determining the resonant frequency of a narrow passband filter. I can't imagine what else you want.
Kevil
Joined Jun 28, 2020
224
OK got it. The problem was that I thought it would be possible to display the frequency next to max. Vout by a command.
I have to use the trick with epsilon and use formula for BW. It's working :).
