LTspice giving weird results in simulation of Phase Shifted Full Bridge Converter.
Darrell_3011
Joined Jun 12, 2021
6
I am trying to simulate a Phase shifted full bridge converter in LTspice. I had already simulated it in matlab simulink and obtained the desired results, but I am redoing it in LTspice to include the effects of non-ideal components. In order to avoid the pulse generation, I imported the switching pulses datapoints from simulink. I have thoroughly checked it and there's no issue with my switching pulses. However, the same circuit in LTspice behaves very weirdly.
This is my model:
First of all the current on primary is weirdly high around 3kA, around where as it is 25A in simulink.
This is the output DC waveform ( whereas I am expecting stable DC of around 85V as I had obtained in simulink.)
I suspect it is an issue with the transformer, but I am not able to pin-point it exactly. Any suggestions are greatly appreciated.
I have attached my .asc file and switching files. Switching files are here: https://drive.google.com/file/d/1tLZM8kkn67f_8aJ7yVGEoM2VJtFOKcpa/view?usp=sharing
38,423
Do you have a small non-overlap time in the switch timing?
Try grounding one terminal of the the switch control lines and one terminal of V1.
Spice doesn't like floating nodes.
Darrell_3011
Joined Jun 12, 2021
6
No, there's no deadtime in the switch pulses. Is that what you meant? The pulses work perfectly alright in MATLAB simulink, its a LTspice specific issue.
Doing that it tells me matrix irregular. And anyway I can have only 1 ground, either on primary or secondary.
38,423
MATLAB may not simulate the large cross-through currents.
Add a small amount of deadtime to the LTspice simulation and see if that makes a difference.
That may be true in practice, but Spice is problematic with floating components.
You can simulate two grounds by connecting the input circuitry common connection to the output ground through a 10megohm resistor.
eetech00
Joined Jun 8, 2013
4,704
There should be dead time (at least 150ns-300ns) between the opposite polarity switches.
The transformer ratio should include a secondary peak output voltage of 85v + the diode bridge voltage drop.
The voltage sources should be grounded.
Yikes!...the stimulation files are gigantic and take quite a while to load.
Better to have a single clock/deadtime generator.
Danko
Joined Nov 22, 2017
2,154
Found error: In TS circuit parallel resistance of L2 is 18mΩ.
Should be something like this:
ADDED:
From 4.076 kW consumed by circuit from V1,
2.937 kW dissipated by diodes D1 - D4,
and 1.0675 kW go to load R2.
