It's actually not the same concept, I've tried adding Bv with V=5*(I{R2}) and it also turned out to be incorrect so I'm not sure where the mistake is happening.Didn't you learn how to do that in your previous thread?
But it don't think the above circuit can work, since the current source is multiplying its own current which would lead to infinite current..
Read my second comment.so I'm not sure where the mistake is happening.
It worked! Thank you so much. I've never used the h component before.like this
That's a neat bit of lateral thinking...You can use R2 for the current source.
Connect the control terminals for the voltage-controlled voltage source in your first schematic across R2.
Then calculate the proper gain for the voltage source to give you 5i2 for the overall gain.
No.Notice that the controlled voltage source's control law says that the voltage developed by the controlled source is proportional to the current through itself. What other two terminal component has the property that the voltage across it is proportional to the current through it? A resistor!
The controlled voltage source can be replaced by a 5 ohm resistor and the circuit behavior will be unchanged.
Yes
A voltage source can generate or absorb power depending on the direction of current flow through it.The voltage source generates voltage and power.
A resistor doesn't do that.
You are right, of course.A voltage source can generate or absorb power depending on the direction of current flow through it.
In this specific case, yes it can. But if the controlling current source was in a different branch then not.Notice that the controlled voltage source's control law says that the voltage developed by the controlled source is proportional to the current through itself. What other two terminal component has the property that the voltage across it is proportional to the current through it? A resistor!
