LTSPICE chokes modelling
FuseFuse
Joined Feb 8, 2017
37
Good morning,
I'm trying to work on a model of an EMC common mode choke in LTspice (in the attachment).
It's a three phase choke and I need to define 6 external ports (nr. 1,3,5 at input side / nr. 2,4,6 at output side) and 3 internal ports (nr.7,8,9). Actually it seems there is some error with syntax, since this model crashes on a simple test circuit as sketched below
Ports 7,8,9 are internal nodes and don't need to be connected externally. Nevertheless, this model works only in case if 7,8,9 ports are not used.
Any tips on what's the issue about this modelling?
Thanks for your help.
ericgibbs
Joined Jan 29, 2010
21,586
hi FF,
Do you have a simple wiring diagram showing the actual component configuration so that we can check the .net.?
E
FuseFuse
Joined Feb 8, 2017
37
hi FF,
E
Yes, sure. I attached it to this message. Ports and components naming is consistent with .sub file I already shared in the previous post.
eetech00
Joined Jun 8, 2013
4,729
Good morning,
Hi
two problems:
1. The subckt statement is missing a "params:" keyword following the pin mapping. The "params:" keyword informs spice that the items following it are parameters.
2. Parameters are missing for rs1_b, rs2_b, rs3_b
Corrected file "Choke_model_7-x.sub" is attached.
FuseFuse
Joined Feb 8, 2017
37
Hi
two problems:
Thank you very much. Now it's working.
I wonder why this model works without "params:" in case if 6 ports only are defined.
I also noticed that the model works only on condition that DKIH-3352-16D5 naming in line .subckt DKIH-3352-16F5 1 2 3 4 5 6 7 8 9 params: is not modified. For example, if I change it to DKIH-3352-16F5, the follow error appears
Can you explain me why?
eetech00
Joined Jun 8, 2013
4,729
The "params:" keyword is only needed if there are parameters defined on the .subckt line. This is the correct syntax.
Some spice programs do not enforce use of this keyword. However, to ensure compatibility, the keyword should be used.
Why do think the keyword shouldn't work without parameters?
The error message is telling you there is no definition for "DKIH-3352-16F5" that can be located in the default locations or in your model definition file "Choke_Model_7.sub". The message is accurate. There is no definition for that name in your model definition file.
