LTSPICE Bipolar input is unipolar on output
Geo_ICE
Joined Jan 29, 2025
I am trying to create a simple circuit to test gate drive transformer models. My +/- 5V Input is fine but the secondary outputs go from 0 to +25V and 0 to -25V. I am expecting to see a bipolar output. (The transformer is 1:2.5:2.5). What am I missing?
Alec_t
Joined Sep 17, 2013
15,152
Welcome to AAC!
With such high values of inductance and such short pulses you may have to run the sim for a lot longer to get the +- waveform you want. Try 1 sec.
eetech00
Joined Jun 8, 2013
4,724
The inductance ratio should be the square of the turns ratio.
so inductance is 1/6.25
For example, If Lp is 1m then Ls is 6.25m
Your values are correct.
Your graph is correct also.
One output is 0 to+25v. The other is 0 to -25v
Alec_t
Joined Sep 17, 2013
15,152
For the short sim time you are using the graphs appear correct. Big inductances slow down current change. Your inductance values (in Henries) seem way too high for a gate driver application.
