Hi all,
I'm writing since I need to simulate on Spice the breakdown effect of avalanche BJT transistors. Now, the Gummel-poon model does not describe this phenomenon, so I came across several options. The first one is the VBIC model, which should be supported by LTspice, but it is hard (if not even impossible) to find some models around. I also wrote to Diodes Inc. to ask for VBIC models of some of their avalanche BJT, but I never got a reply.
The same is for the Mextram BJT model.
Now, I recently came across the @Bordodynov outstanding LTspice library, and I found some avalanche BJT models fully working in the breakdown region!
Since I need it for a High voltage pulser, I have to use some BJT with higher BV voltage, such as ZXT415 or FMMT417, and I'd like to ask @Bordodynov some additional information on how you modeled this effect in the example transistors you included in your library. Do you have some references? how can I replicate this model for those BJT I mentioned? Do I need some experimental data? thank you so much in advance!
