LTSpice: Assigning a node voltage to a parameter not work
5O5mm
Joined May 15, 2021
15
Appearently it is not supported (?) Could you give any idea how to use any node voltage value in .param statement ?
Here I simplified the question actually I need this for a different circuit but its basically the same problem.
eetech00
Joined Jun 8, 2013
4,724
Parameters cannot be used with node voltages.
Parameters are static values and are evaluated before the simulation is run.
ericgibbs
Joined Jan 29, 2010
21,567
hi ee,
I would like to see the TS's original problem, the posted circuit is a different/basic circuit.
There maybe other solutions to his problem.
E
