LTSpice and CD4013
Status
Not open for further replies.
Jony130
Joined Feb 17, 2009
5,599
Hi, I have a question.
Why this circuit do not work as expected?
As you can see I set-up 4013 as a non-inverting buffer with hysteresis.
But this circuit do not work in LTspice only circuit with the 4049 gates work. Do anyone knows why is that ?
38,759
.........As you can see I set-up 4013 as a non-inverting buffer with hysteresis........
But you haven't.
CLR is constantly high so the Q output is constantly low.
But, the real problem is, CD4013 can't be configured as a non-inverting buffer.
Why/how did you think it could be?
Jony130
Joined Feb 17, 2009
5,599
But in real life this circuit work as a non-inverting buffer with hysteresis .
Take a look at CD4013 data sheet
http://www.ti.com/lit/ds/symlink/cd4013b-mil.pdf
https://www.nxp.com/documents/data_sheet/HEF4013B.pdf
http://www.onsemi.com/pub_link/Collateral/MC14013B-D.PDF
This might be the case in LTspice.
Robin Mitchell
Joined Oct 25, 2009
819
38,759
Yes, it would appear that the LTspice model doesn't properly simulate Q going high when both the PRE and CLR are high, which is not a typical operating configuration.
eetech00
Joined Jun 8, 2013
4,724
Hi
Back in 2013, an issue with the 4013 was identified that as since been corrected in the library file.
I think your using an old version of the CD4000.lib file.
The OPs asc file works on my system
Jony130
Joined Feb 17, 2009
5,599
OK, I manage to download a new library file. And now everything work as it should
Voltage on PRE (S) input in LTspice
And the same voltage on pin S (PRE) measured in real circuit via Rigol.
Thanks to all for your help.
hsc
Joined Dec 21, 2016
1
Hi all,
I tried to start this simulation too, but LT spice has problems to open the lib. Whats wrong with the lib? Or is there a special setting necessary?
ScottWang
Joined Aug 23, 2012
7,505
Hi all,
Download the file CD4000_v.lib that I attached in #11, and put into the directory as sym where you installed the LTspice software, and open the CD4013_onoff.asc, when the error occurring then go to modify ".include cd4000.lib" and using the browser to find the CD4000_v.lib where does it located as above described.
eetech00
Joined Jun 8, 2013
4,724
Hi all,
The CD4000_v.lib file should be located in the schematic folder or the program installation folder LTspiceIV\lib\sub".
Then place the following directive on the schematic: ".inc CD4000_v.lib" without the quotes.
You must place a voltage source with a VDD label on the schematic to provide the internal supply voltage to the component, or an error will occur.
Status
