Ltspice 8390 Feedback pin (Micro-controller with D/A)
Bhargav Jani
Joined May 20, 2016
114
Hello ,
I wish to simulate theLtpcie LT 8390 4 switch buck-boost controller in master slave config as shown in the fig ... I wish to control the sch with the help of micro-controller. Is it possible to connect the micro-controller to Fb pin of the model ?
Any suggestions on connections through D/A converter with micro.controller to ltspice
Bhargav Jani
Joined May 20, 2016
114
To control the output voltage , current. The micro-controller will have a CAN (Controller Area Network) which will be providing and taking signals from ECU (load which draws current).
There are few voltage discontinuity tests which I have to perform
And so Micro-controller is necessary in the design.
You meant FB pin can be connected to D/A of micro-controller (provided the voltage is in the range of 3.3-5 V)?
Alec_t
Joined Sep 17, 2013
15,156
I'd include a series resistor between the FB pin and the D/A output. The value would depend on the characteristics of the D/A converter (of which I have no knowledge).
