LTS Transformer and Scaling Oddity
SamR
Joined Mar 19, 2019
5,524
Need a transformer model that allows for turns entry. Also, for some reason some of my text and symbols have taken on different sizes? It seems my Voltage models have shrunk? For example...
SamR
Joined Mar 19, 2019
5,524
@Delta Prime That should work since I just need a simple straight forward ideal model for now.
@Bordodynov I already have your model set but seems this is in addition? I do want to thank you for your extensive model set. Impressive work!
Seems I need more education on the net list programming.
Papabravo
Joined Feb 24, 2006
22,105
Text and symbols changing sizes indicates there may be other problems of which you are not aware. The inability to find the subcircuit for a symbol is indicative of a broken link between the symbol called out in the schematic, the first occurrence of that symbol name in your directory tree, and the name of the subcircuit called out by the symbol.
Size changes for symbols happen when you have multiple symbols with the same name and they each have different graphics.
Changing text sizes happen when you have old schematics with a text size of 0, which used to be the "default", but now represents the smallest size.
Your transformer symbol is used for the "mythical" DC-DC transformer described in Basso's book on Switch-Mode Power Supplies.
EDIT: Found it
SamR
Joined Mar 19, 2019
5,524
A quick way is to calculate pri/sec inductance using "the square of the turns ratio" method.
Then adjust the values for frequency.
This is something new that I have not seen before in my studies. I understood the video that DeltaPrime linked to using the square root of the inductance to determine the turns ratio. Which is obviously the reverse method of getting inductance from turns. How does that then get adjusted for frequency? What I am presently working with is all 60Hz power supplies at various voltages.
eetech00
Joined Jun 8, 2013
4,723
Spice transformers can get complex in a hurry. But to keep it simple, once you have the correct inductance values, adjust the inductance values, while keeping the ratio constant, so that the reactance satisfies the (current transfer) load requirement.
Here is an LTspice transformer document:
Papabravo
Joined Feb 24, 2006
22,105
As you know the inductive reactance is a linear function of the frequency. As the frequency goes up you want to make the inductance smaller so that the inductive reactance does not get too large. You can easily use a spreadsheet to compute the reactance for a fixed frequency. Like this:
Inductive Reactance​
Frequency​
60​
Hz.​
Inductance​
Reactance​
10.00E-06​
0.00376991118430775​
Ω​
100.00E-06​
0.0376991118430775​
Ω​
1.00E-03​
0.376991118430775​
Ω​
10.00E-03​
3.76991118430775​
Ω​
100.00E-03​
37.6991118430775​
Ω​
Reactance is not of much concern at low frequency​
Frequency​
100.00E+03​
Hz.​
Inductance​
Reactance​
10.00E-06​
6.28318530717959​
Ω​
100.00E-06​
62.8318530717959​
Ω​
1.00E-03​
628.318530717959​
Ω​
10.00E-03​
6283.18530717959​
Ω​
100.00E-03​
62831.8530717959​
Ω​
Even 1mH has significant reactance @ 100kHz​
SamR
Joined Mar 19, 2019
5,524
OK, what I am doing is using the ideal model for the XFMR so the reactive inductance does not come into play. One of these days I will get around to finishing Malvino's Resistive and Reactive Circuits...
eetech00
Joined Jun 8, 2013
4,723
If you're using inductors in an AC transformer, there is still inductive reactance.
So unless you want get fooled, better to check the output with the anticipated load.
Papabravo
Joined Feb 24, 2006
22,105
The model you posted originally, is for an ideal "DC-DC Transformer". This part does not exist in reality. It is used to investigate the behavior of DC-DC converters. I believe it is a serious mistake to use it in conjunction with the circuit in your original post. Just use the coupled inductors. You will avoid getting tricked by the results that you observe.
Papabravo
Joined Feb 24, 2006
22,105
That was just noodling around with what was available in my libraries. Think I have the answer to what I am currently working on from the old LTS4 video on the AD site.
Nothing wrong with that, but it helps to have some context when that is available. I did not come by all these examples that I've posted overnight.
