LT8362 output voltage dropping under load
DaivdA
Joined Jun 6, 2024
I'm trying to build a step up converter to for from 6.5-8.3V DC all the way up to 48V with a maximum load of 15W.
I've gone with SEPIC configuration of an LT8362. I've gone with SEPIC over boost only to allow the output to be switched off completely.
My schematics attached below.
The problem I have is this. At no load Vout is a nice 48V, however as the load on the output goes above 2W, Vout drops back down to about 20V. Is someone able to give me some tips on what I can do to try an diagnose and resolve this problem?
I did try cutting some tracks and removing C3 to switch it over to a boost converter. I had the same problem but at 2.3W rather than 2W.
I was able to use LTSpice to simulate the circuit but the output was stable.
C3, C11Ceramic Capactior 1206 1uF 100V X7RSamsungCL31B105KCHSNNE
C10Ceramic Capactior 4.7PF 100V C0G/NPO 0603YAGEOCC0603CRNPO0BN4R7
C12Ceramic Capactior 0603 10nF 16V X7R YAGEOCC0603KRX7R7BB103
C14Ceramic Capactior 0603 1nF 100V X7R Samsung Electro-MechanicsCL10B102KC8NNNC
R1, R2RES 1M OHM 1% 1/10W 0603Stackpole Electronics IncRMCF0603FT1M00
R4-R6, R8RES 34K OHM 1% 1/10W 0603Stackpole Electronics IncRMCF0603FT34K0
R7, R9RES 0 OHM 1% 1/10W 0603YAGEOAC0603JR-130RL
Q20.17A Id, 100V Vds, N-Channel MOSFET, SOT-23 BSS123-7-F
C1, C2, C4-C9Ceramic Capactior 0603 4.7uF 100V XR7KYOCERA AVX12101C475K4T2A
U1Switching Voltage Regulators Low IQ Boost/SEPIC/ Inverting Converter with 2A, 60V SwitchAnalog DevicesLT8362EDD#PBF
L1INDUCT ARRAY 2 COIL 15UH SMDBourns Inc.SRF1260-150M
D1Diode Schottky 150 V 1A Surface Mount SOD-123FLSMC Diode SolutionsDSS115UTR
Q1MOSFET P-CH 30V 8A 6TSOPVishay SiliconixSI3421DV-T1-GE3
F1FUSE 0603 6A , 70A In rush currentAEMF0603HI6000V032TM
DaivdA
Joined Jun 6, 2024
What happens to the battery voltage? What type and size of battery are you using?
I'm not using a battery for testing. I've got it hooked up to a 300W bench supply running at 6.5V. I put an oscilloscope probe on pin one of the inductor and it was stable at 6.5V.
I've got the output connected to a dummy load set a to a constant power output.
If I changed the input voltage to 8.3V I was able to increase the output load by about 0.1W before the output voltage dropped off.
Ian0
Joined Aug 7, 2020
13,158
The LT8362 is limited to 2A. You are asking for 15W/6.5V=2.3A even if it were 100% efficient, and there were no current ripple.
DaivdA
Joined Jun 6, 2024
Thankyou, That may explain it. I don't know how I missed that. I'll order an LT8364 in and see if that fixes things it's a 4A version of the same part.
Ian0
Joined Aug 7, 2020
13,158
Make sure that you accurately calculate the peak current.
On an ordinary flyback converter, it can be as much as 6 times the average current. On SEPICs it will be less, provided that the input current remains continuous.
DaivdA
Joined Jun 6, 2024
Just an update to anyone else who has the same issue. I was able to improve the performance by lowering the switching frequency down to 300kHz. This allowed me to get about 6.5W out of the device before the output voltage dropped off. Not the 15W I needed. (The LT8364 had a very similar performance, although not sure if that had something to do with only one SW pin being connected.) In the end I've decided to spin up another design using a switch mode controller with an external MOSFET in a boost configuration to keep things simpler.
