I'm just starting out with LT spice and wanted to simulate a single-channel inverter with Schmitt trigger. I went into the components window and selected the "Behavioral Schmitt-Triggered inverter", which is in the picture below. I see two inputs and an output. Do I not have to connect it to a power supply and is there a symbol anywhere which tells me what the actual pins are? The logic diagram on the datasheet I'm using for the part I want to simulate only shows one input and one output. I assume I don't need to model the exact component I need to simulate and can use the default LTSpice component. Should I be downloading componets to simulate from somewhere?
Picture of LT Spice:
Datasheet for schmitt inverter I wanted to use:
https://www.diodes.com/assets/Datasheets/74LVC1G14.pdf
