LT Spice - Bridge Rectifier Simulation Help needed
Alec_t
Joined Sep 17, 2013
15,167
Node n001 is at the top of the V1 source, so you are measuring the voltage there with respect to ground. To measure the input peak-to-peak, click and drag the mouse between the top (n001) and bottom (n002) of V1.
eetech00
Joined Jun 8, 2013
4,749
Hello Guys,
What is missing in my Circuit ?
I cant figure out why input is peak not peak to peak.
Alec_t is correct.
If you probe a single point, the point of measurement will be referenced to ground by default.
If you probe two points, using the click and drag method, then the measurement will be taken between the two selected points.
