Low to high impedance infor required
PCB ZAR
Joined May 16, 2025
Hi Guys,
New to the site.
Can anyone direct me to the right chat.
I'm a novice at best, looking for information on a adapter i would like to modify. 9v system low to high impedance its related to aviation headsets.
Kind regards
Wayne
wayneh
Joined Sep 9, 2010
18,164
What’s the problem you’re trying to solve?
It‘s ok to plug a high impedance load (headphones) into a low impedance source (amplifier). The reverse is not true: an 8ohm speaker plugged into a headphone port might overload the source.
28,278
Certainly an 8 ohm speaker connected to a high impedance headphone output will not perform very well. In addition, in some of those poorly designed circuits, it may cause damage.
But the meaning of " 9v system " is a bit unclear to me, especially as it relates to headphones. What sort of output is the TS wanting to connect to an aviation type headphone??? There is a lot of information not given.
