- Joined Jan 23, 2018
- 27,587
Does your tow vehicle produce enough vacuum to operate a vacuum powered brake controller in a useful manner? That would be my big concern. Also, there would need to be a fair sized tank on the towed vehicle to assure an adequate supply in case of repeated hard braking efforts. An electric servo would be simpler and smaller and it could run off of the towed vehicle battery. In addition, wiring is often simpler than hosing in a vacuum connection. And certainly towing a vehicle is indeed quite different from towing any large and heavy trailer. Both the weight distribution and the steering are totally different, the only similar part is the need for reliability and adequate control.
Another concept would be a hydraulic servo, pressure controlled, driving the towed vehicle's brake pedal from a small hydraulic cylinder. A small hydraulic pump and an accumulator and it could be very effective and quite reliable. And the technology for such is totally mature, all of the pieces are "off the shelf", produced by companies well experienced in the technology. Not as cheap, but very fast and effective. So there is another choice to think about.
