Low-Power Schottky TTL Models For LTspice
22,099
Hello:
Could someone tell me where I can find Low-Power Schottky TTL Models For LTspice?
Thanks,
RS
If neither @Bordodynov nor the LTspice group at groups.io have them then they likely do not exist.
The closest equivalent would be the 74HCTxx libraries. At least when it comes to logic thresholds - allegedly.
ETA: The users' group at groups.io has a few LS parts in the files section.
22,099
For most logic devices there are two kinds of models that you can aspire to use. @Bordodynov has kindly shown you a transistor level model of a 2-input NAND gate and a transistor level model of a D-type flip-flop; and you have the temerity to ask "What?" The nature of that one-word question is just plain rude! The other type of model that you might find is a behavioral model. These are often used in an analog simulator to produce faster results, but only in the behavioral sense.
RRRRSSSS
Joined Jun 16, 2023
128
LOL. Stay out things that don't concern you!
Audioguru again
Joined Oct 21, 2019
6,826
Didn't most of us start with vacuum tubes, then germanium transistors, then silicon transistors, then RTL, DTL, TTL and LS-TTL logic, then Cmos logic, then Mosfets?
