If neither @Bordodynov nor the LTspice group at groups.io have them then they likely do not exist.Hello:
Could someone tell me where I can find Low-Power Schottky TTL Models For LTspice?
Thanks,
RS
I have shown that I have hierarchical models of a logic gate and a clocked trigger. A more specific question needs to be asked. And it is not clear why you need it. What is your purpose?What?
LOL. Stay out things that don't concern you!For most logic devices there are two kinds of models that you can aspire to use. @Bordodynov has kindly shown you a transistor level model of a 2-input NAND gate and a transistor level model of a D-type flip-flop; and you have the temerity to ask "What?" The nature of that one-word question is just plain rude! The other type of model that you might find is a behavioral model. These are often used in an analog simulator to produce faster results, but only in the behavioral sense.
What's with the attitude?LOL. Stay out things that don't concern you!
If it's no concern of the members of the forum, why did you post the question?LOL. Stay out things that don't concern you!
But @Bordodynov's diagrams are for the much more modern LS series, which was introduced as recently as 1971.Antique TTL logic was used 58 or 60 years ago.
I refuse to comply with such a rude request. I intend to try to help you despite your petulance.LOL. Stay out things that don't concern you!
You of all people should know the answer to this one and it is the same reason that people still try to design audio circuits with the μA741 of which your oh so fond. ROFLMAO.Why would anybody use very old LS-TTL logic ICs today? I used Cmos logic many years ago.
All of the above and then some!Didn't most of us start with vacuum tubes, then germanium transistors, then silicon transistors, then RTL, DTL, TTL and LS-TTL logic, then Cmos logic, then Mosfets?
| Thread starter | Similar threads | Forum | Replies | Date |
Toshweld ARC-200 welder: fan runs but display and power LED are off | Technical Repair | 1 | |
Peak Power vs. Peak Wattage | Off-Topic | 52 | |
| S | Green Laser power supply | General Electronics Chat | 14 | |
| S | SMPS Power Schottky rectifier replacement | Technical Repair | 8 | |
| D | power Schottky rectifier good or dead? help | Power Electronics | 5 |
