Low Power Class AB Amplifier
maker_2023
Joined Nov 20, 2023
199
Can you convert that file to some other format?
It just the LTSpice .asc file for that nice amplifier circuit that you posted earlier.
At this point I have only simulated the circuit but I intend to breadboard it soon.
It looks like the current through R6 is only 961 uA.
M
Audioguru again
Joined Oct 21, 2019
6,826
It looks to me like R1 from the output to the base of Q1 is providing some negative feedback.
I mentioned the original circuit that has R1 connected to VCC.
The idle current (with no input signal) of the entire amplifier circuit is mostly from the output transistors. Then at low signal levels the output transistors operate at class-A producing no crossover distortion.
sghioto
Joined Dec 31, 2017
8,750
Probably. The 10ma refers to the total current with no input signal which is mostly the output transistors as mentioned previously.
Have you tried using different values for R5 up to 1K in the simulator?
maker_2023
Joined Nov 20, 2023
199
The total current drain on the sup
The current drain on the supply is only 1.5 mA (per simulation) with R5 at 500 ohms. The value of R5
doesn't seem to affect the cuurent drain at all.
M
sghioto
Joined Dec 31, 2017
8,750
If you build the circuit as designed R5 will definitely affect the current drain.
I found that 10ma was sufficient to remove any crossover distortion.
maker_2023
Joined Nov 20, 2023
199
Hi.
I am going to breadboard this circuit in the next while. I will let you know how it goes.
M
38,772
For your interest, below is the sim of a perhaps more elegant circuit, that uses a differential input stage (Q1 and Q2) with both AC and DC negative feedback from the output to bias the output at 1/2 the supply voltage largely independent of transistor or diode variations, establish the gain and reduce distortion (around 0.2% in the sim).
I think it's one of the better simple AB audio amp designs, due to the negative feedback that stabilizes the DC output operating point at 1/2 the supply voltage and gives low output distortion.
maker_2023
Joined Nov 20, 2023
199
Thanks. I will delve into this circuit also.
38,772
Or P2N2222A or PN2222
Those are plastic package versions of the 2N2222(A).
In that circuit you could also substitute most small NPN's such as the 2N3904.
