Low Power Class AB Amplifier
RRRRSSSS
Joined Jun 16, 2023
128
I found this low power class AB amplifier schematic and did a sim. Is resistor RF a DC negative feedback
resistor? How would a designer decide what value this resistor should be?
Ian0
Joined Aug 7, 2020
13,281
Yes - it is a DC feedback resistor.
A real designer wouldn't use that circuit, as it would set the DC level at Vbe+V(RB2) without the ability to change it.
RRRRSSSS
Joined Jun 16, 2023
128
LOL. Now that we have established that the designer wasn't real, what would the appropriate circuit be?
It always amazes me that so-called experts put circuits like this out there. It makes it hard when you are
trying to learn.
RS
RRRRSSSS
Joined Jun 16, 2023
128
There would be another resistor between the base of Q1 and ground so that Vout*Rnew/(Rf+Rnew)=Vbe
Thanks Ian. So If I set the circuit up like the attached, the voltage on the base of Q1 should be 0.7 volts?
35,193
This is a circuit I threw together quickly. It is almost identical to your circuit originally posted. It works well enough for my purposes.
If yours does not work, check the wiring or the transistor leads identification.
RRRRSSSS
Joined Jun 16, 2023
128
Your circuit is biased wrong and has a very low gain.
I fixed it but the transistors are overloaded.
I improved it with more powerful little transistors.
Hi AG
Thanks for all your work. I ran the sim and found that if I replace the 2 diodes
with a 2N4401 and a 2N4403 in a diode configuration and increased the power
supply voltage to 15 volts. The THD decreased from 11.8% to 1.6%.
I do have some questions regarding some component values:
1) How did you arrive at the values for R2, R3, R4 and C4?
2) What does R1 do and how did you know what value to use?
3) Is C2 just used to provide additional power supply filtering?
Again, thanks.
RS
Ian0
Joined Aug 7, 2020
13,281
Hi AG
What happens to the bias current?
RRRRSSSS
Joined Jun 16, 2023
128
Thanks. I ran a sim and there is 7% THD (some crossover) and very little output (240 μW).
Audioguru again
Joined Oct 21, 2019
6,826
R1 increases the input impedance so it is not simply the base-emitter diode of Q1 (as a signal rectifier) and roughly sets amplifier gain.
Your Sept11 schematic has a very low input level of 38mV peak and with the gain of only 10 times, the output power is only
0.009W.
I used simple calculations and a bit of cheating for resistances and capacitances.
RRRRSSSS
Joined Jun 16, 2023
128
0.009W.
The ouput is 125mW and the THD is 6%? Wasn't this circuit a 1 watt amplifier?
Audioguru again
Joined Oct 21, 2019
6,826
The output is 125mW and the THD is 6%?
No. The output of my amplifier on post #15 is undistorted 4V peak which produces an output power of 2W peak which is 1.0W continuously into the 8 ohms speaker. The distortion is fairly low for such a simple amplifier.
Years ago I built an amplifier for a TV. I used an LM390 amplifier IC that is similar to an LM386 but it uses bootstrapping for a higher output voltage swing. it produces 1.13W into 8 ohms at low distortion with a 10V supply.
RRRRSSSS
Joined Jun 16, 2023
128
Here is what I get. Don't know why mine is different.
RRRRSSSS
Joined Jun 16, 2023
128
Your amplifier has a 0.5V peak input signal which causes the output to have bad clipping.
My amplifier in post #6 has an input of 0.38V peak then its output has no clipping.
In your post #15 you had a 0.5 volt input signal and a peak output voltage of 4.0. My circuit is
identical as far as I can see.
